0 registered (), 295 Guests and 60 Spiders online.
#595146 - 04/23/18 03:27 PM Concho 2018 - Limbo Contest Pictures!!
EnderTheX Offline
Hey Yall, I have organized and uploaded all my Limbo contest pictures to the link below. I took 10 pic/second of each rider in each run and I found the "best" picture in each part. The only one that has two pictures of the same run is the winner with both his under the bar and crashed pic.
If you see the limbo bar in any position other than "drooping" it means the rider has hit it and they certainly knocked it off. I tried to capture the moment they hit but it doesn't translate that well to if it got knocked off or now.
The gallery is organized from last to first so you will see the action in reverse (it was too easy at the start!)
They are all in high resolution and free to download! Enjoy!
https://enderthex.smugmug.com/Concho-2018-Limbo-Contest/
#595147 - 04/23/18 03:32 PM Re: Concho 2018 - Limbo Contest Pictures!! [Re: EnderTheX]
EnderTheX Offline
I didn't stick around too long at the end so I assumed the last guy who made it but crashed was the winner...? Here is the last clearing pass:
Last Clearing Pass
Moderator:  pentonrider
