828
42
#505909 - 06/04/11 08:41 PM
Re: YZ125 144 kit?
[Re: joseschopshop]
Loc: Camp Buehring, Kuwait
Good looking bikes. I installed a big bore kit on MXTerri's son Justin's YZ125. It was an easy to do deal, even though I had to relieve the cases so the rod would clear. You could tell it had more displacement, but it wasn't enough to make a big difference when hauling my 160 pound butt around. Justin loved it, but he was 5'5" and around 130. If I was spending time and money on it I would go with the 250.
Wayne 919
HAMPTON RACING TexasPhotocross Cycle Nation Powersports NO TOIL
#505911 - 06/04/11 10:23 PM
Re: YZ125 144 kit?
[Re: 2old2slow]
Loc: Austin, Texas
I got some YZ465 pistons you can try.
Harold Snyder 1980 YZ465G (owned since 1984) 1980 YZ465G #2 (Project For My Son) 2007 YZ85 (sons) 1970 Dodge Dart 622ci, 1404hp & 1076tq (IHRA Top Sportsman) 2008 JR Dragster B&S 40hp (sons)
#506120 - 06/07/11 09:32 AM
Re: YZ125 144 kit?
[Re: Snyder]
Loc: San Antonio
My favorite two bikes of all time are my late model YZ125 and YZ250. Both of which I bought used with low hours, for a small fraction of the price of a new bike. I've ridden a few 144s (none were Yamahas, though), and they are great fun. It all depends on what type of power you ask for. I have a few friends that have had them done by Eric Gorr, and every one of them has been more than satisfied. Ardfarkl on here had a YZ144... maybe he will chime in.
I have given a lot of thought to turning mine into a 144, but I just really enjoy my 125 the way it is. Hands down, its the most fun bike on the market. I probably will send it off to Eric Gorr eventually, though.
The Athena 144 kits aren't very impressive, due to the porting specs (which are almost identical to the stock 125 cylinder, from what I've read). Adds some low end, but is kind of flat on top. With some port work, they rip and are a viable option since you'd then have an extra cylinder lying around.
#506253 - 06/08/11 10:59 PM
Re: YZ125 144 kit?
[Re: Motomofo1]
Loc: Austin,TX
Thanks guys.Hard hard call.........The little turd was super mean for a bone stock 125 before I tore it down.I'm torn between going back stock or big bore.I hope Mike will go into detail on the before and after fun factor.
Does anyone have a spare five gallon steel bucket I can use as a new jug for the YZ465 piston?I wonder if that 465 piston would make it shake the grips.......?I'll need a cheater pipe for my little kick starter too.
1977 DG monoshock XL75 1978 PK Racing XR75
#506269 - 06/09/11 07:42 AM
Re: YZ125 144 kit?
[Re: joseschopshop]
Loc: Usually on here.
Eric Gorr did my 144. It was incredible. Pissed off some 450s with that thing! Beebout loved it too. That thing rocked!
What I would do is get Eric to do a 144, but use one of his cylinders. It is no ttha tmuch extra and you can put it back if you prefer it the other way. Plus it is a good selling point should you decide to do that!
I WANNA RIDE ONNNNNNNE!
Mike #689
My mom hung me on a hook once...ONCE!!
#506320 - 06/10/11 01:06 AM
Re: YZ125 144 kit?
[Re: ardfarkl]
Loc: Austin,TX
Mike,It will be a good while before I'm finished with them.I'm thinking when the temps cool down a little I might give it a try and see what happens.I'm in no shape to ride at this point,so I'll be taking my time........I bought two,so I just happen to have a spare.That will piss Mark Cody off real bad when his wimpy little 450 gets spanked by a pair of screamin' 125's!
#506788 - 06/16/11 11:15 AM
Re: YZ125 144 kit?
[Re: joseschopshop]
Loc: Austin, TX
You gotta do the 144. I bought a 136 E.G. complete topend for my '83 yz125 at the beginning of this year and it screams. The bigger bore and porting made a big difference. It came with the new rebuild kit & gaskets, used intake manifold, reed cage with boyessan reeds, and all bolts for $375 shipped. I wanted to build an aluminum frame yz144 recently but the blownup bike that I found on CL sold pretty quick. The 144 is worth the money if you prefer to ride a 2stroke.
When in doubt PIN IT...it may not solve the problem but it will damn sure end the suspense!
#507122 - 06/21/11 08:12 PM
Re: YZ125 144 kit?
[Re: d_alexand]
Loc: Austin,TX
Thanks for the input.I'm torn between OEM Yamaha parts and an Eric Gorr top end.I'm tempted to leave the nicer one stock and mod the other bike.I like the idea of being able to drive to Kasson's and pick up a stock Yamaha top end kit.A stock Yamaha cast piston has it's advantages over a Wiseco if replaced often.Years ago I was told that the only replacement for cubic inches is more cubic inches.I assume the same theory applies to cubic centimeters.With that said,I'm torn between stock,134cc's and 144cc's.I have also put some thought into a 153cc kit on one since I plan on replacing the crank anyway...........
