0 registered (), 1215 Guests and 20 Spiders online.
#406295 - 03/29/09 08:46 PM 01 Warrior 350 is not starting
JK5 Offline
Loc: Portland, Tx
Ok, Never had a problem until now. I rebuild the carb just because it is 8 year olds and running ruff. After the rebulit i was adjust the idle and everythig else. After I had it running right I let it sit before i went to ride it again, when I try to start nothing happen other than a spinning nosie, I thought it was the starert so i bought a new one and replace it. But still NO go, I think it may be the starter Clutch however after being down for a week or so it started up and then fail again. I not sure if I should replace the starter clutch or troubleshoot something else, If anybody has some advice or had the same problem let me know, Oh yeah the battery is good and i have good compression
Thanks
Brian
2001 Yamaha 350 Warrior(Warpig)
2006 Yamaha TT-R 230
#406313 - 03/29/09 09:48 PM Re: 01 Warrior 350 is not starting [Re: JK5]
NIGHTOWL Offline
Loc: pearland texas
i would suggest asking scott(SBR Racing), he is the moderator for the ingleside park forum. he is a wealth of knowledge of most things motorcycle and atv.----jay
my carbon footprint is bigger than yours!!!
#406317 - 03/29/09 10:02 PM Re: 01 Warrior 350 is not starting [Re: JK5]
Babaloui Offline
Loc: Capital o' Tx
My '01 Warrior would always push start and run fine, even with a totally useless starter. After replacing the starter, the button again was my friend. If the quad doesn't stay running after starting then the starter is not the problem.
Tim
#406607 - 03/30/09 09:04 PM Re: 01 Warrior 350 is not starting [Re: Babaloui]
JK5 Offline
Loc: Portland, Tx
Thanks For the advice I will try to get a hold of Scott
