#396326 - 02/03/09 10:16 PM weisco piston / stock jug.ok??? yz85
DANYBOY Offline
Loc: TEXAS HILL COUNTRY
just wandering if anyone knew if its ok to run after market piston kit in stock (not sleeved)cylinder(jug)????? i honed it out some just to clean up for new ring!but still within tolerance .5mm(47.50)
yz maniac.. (2)2001yamaha blasters,98 cr125,2002 xr200,2002 xr100,93 dr350,93 kx80..2005 crf150
#396327 - 02/15/09 10:46 PM Re: weisco piston / stock jug.ok??? yz85 [Re: DANYBOY]
999renville Offline
yes, the wiseco will be on the small size like the a piston. it is forged instead of cast so you need to warm it up a little slower than the cast piston or you can get a 4 corners siezure... no biggie just don't fire it up and go balls to the wall and you'll be Ok.
you can also buy vertex. cheaper and same guys that make the stock piston.
sponsorhouse.loopd.com/Members/999Renville
