476
67
#37324 - 03/20/03 02:06 PM
Re: EZ start campfire
[Re: RockHopper]
Loc: Lewisville, TX
Jeepers,
There are members of the RRDR that need to read this post. They'll definitely pack up and head out with y'all.
Makes me nervous.....
Cowgirl Up!
#37325 - 03/20/03 02:42 PM
[Re: KeltWitch]
CTTA President
Loc: www.austintrials.com
The devil is in the details: Earlier it was mentioned that a "half can of gasoline" was used... He meant that the 12 oz. can is actually cut in half so the can is fully OPEN on top... then only a small amount of fuel is poured inside.. Another great trick for starting fires (and a safer one) is to use deisel fuel. Deisel has a "flash point" (temperature at which a liquid gives off ignitable vapors) much HIGHER than gasoline. Flashpoint of GAS is -45 degrees. That's "minus." So, gasoline is ALWAYS giving off ignitable vapors. Deisel doesn't give off ignitable vapors until it reaches about 145 degrees... So, you can pour deisel over your logs, let it soak in a minute, and then light it up (it won't go "whooosh") you'll have to hold the match until the deisel starts, it takes a few seconds... in a couple of minutes you will have a GREAT fire...  As always, be careful.. use common sense.. keep unused fuels away from all ignition sources..
#37326 - 03/21/03 02:23 PM
[Re: RockHopper]
Loc: Austin
I just rub 2 sticks together.
#37327 - 03/21/03 02:43 PM
[Re: fastmonstr]
AMSA Gang Boss
Loc: Spicewood
Growing up in East Texas and camping deep in the piney woods....my dad would aways find "pine knots" on the ground around the base of big pine trees. He would take these pine knots which are very hard, pine resin concentrated pieces of pine branches....and splinter them up with a hachet. He would light a small pile of these splintered pine knots and stack oak hardwood on top. Pine knots burn like they have been soaked in fuel (the pine resin)....a natural kindling. They smell good when you take the hatchet to them too! Works every time.
Dave Austin MotoSports Association
#37330 - 03/22/03 02:22 PM
[Re: RockHopper]
how about magnesium firestarters, also available at Academy, for you wimps who don't like gasoline in a can?
Hoop 2006 XR650R, the dual sport bike 2004 DL1000, the street bike
#37331 - 03/24/03 05:46 PM
[Re: Hoop]
Loc: Salado, TX
Better yet- camp with your parents in their RV!
No- I have seen Dad "start" campfires and waterheaters and many thuings over the years- Best advice- stay away from Herb in this process. Luckily he has never been hurt- just singed and blow back before-
I think I'd rather go to acadamy anyday than the hospital....
WHATEVER! Kirby's Mom!!
#37332 - 03/25/03 01:47 PM
[Re: Chris]
Loc: Salado, TX
By the way- with all you firemen- any cool firemen calanders out there?
#37333 - 03/26/03 02:58 PM
[Re: Chris]
Loc: North Dallas, TX
Well, I would suggest a fifth of Ever Clear and a nice mullet. First: Douse you mullet with the Ever Clear Second: Light up a Kool Menthol and inhale deeeeeply Third: Watch your mullet ignite Fourth: Stop, Drop and Roll in the fire pit Fifth: Wah-Lah, you have fire, and you don't have a mullet anymore, so DOUBLE BONUS man!
Later, J
