0 registered (), 591 Guests and 25 Spiders online.
#351581 - 05/02/08 05:18 PM Spark Plug Question for a 05 CRF250
3BallzEmpty Offline
I picked up a NGK spark plug IMR9C-9HES. I got home and my book calls for:
Standard 'R0409B-8' or For Extended high speed racing 'R0409B-9'.
Obviously the one I bought isn't close to what the book says so I called the place where I purchased and he said that IMR9C-9HES is what it says in his computer. Does anyone know if it's ok to use the one I bought? These plugs aren't cheap.
dpratt@austin.rr.com 05 CRF250R #187
#351582 - 05/02/08 05:40 PM Re: Spark Plug Question for a 05 CRF250 [Re: 3BallzEmpty]
pmkkdx Offline
per XRs Only
NGK Spark Plugs are performance spark plugs that also serve as a direct replacement on many Honda CRF, TRX and XR dirt bike and ATV applications. FITS: Honda CRF250R (05-06) GAP: 0.036
More OFF-ROAD / DIRT BIKE / ATV Parts Details. . .
PART PRICE: $32.95 PART NUMBER: NGK-R0409B-8
NGK Iridium Spark Plugs are high performance spark plugs that also serve as a direct replacement on many Honda CRF, TRX and XR dirt bike and ATV applications. FITS: Honda CRF250R (04) / CRF250X (04-06) GAP: 0.036
PART PRICE: $12.95 PART NUMBER: NGK-IMR8C-9H
but notice that is for only '04 R but '04 - '06 for X????
but looking at an '05 CRF250R in bikebandit
S/PLG (R0409B-8) or S/PLG (R0409B-9)
~':/ Marcus \:'~
Laughter is the best medicine!!!
(I only have to amuse myself)
#351583 - 05/02/08 05:51 PM Re: Spark Plug Question for a 05 CRF250 [Re: 3BallzEmpty]
pmkkdx Offline
hmmm, then looking at NGK-USA
they don't list an iridium plug for the '05 or '06 ... only '04???
states the standard plug is "Standard R0409B-8 # 7791 gap 0.036"
and the iridium plug for the '04 is "Iridium IMR8C-9H # 3653 gap 0.036 "
then merely doing a yahoo search on the plug number you did get, appears it fits an '05/'06 CBR600RR, CBR1000RR
don't know what to tell you from here... will check specs to see what the difference is... BRB
~':/ Marcus \:'~
#351584 - 05/02/08 05:53 PM Re: Spark Plug Question for a 05 CRF250 [Re: pmkkdx]
3BallzEmpty Offline
I guess I'm going to take this back then!
#351585 - 05/02/08 05:58 PM Re: Spark Plug Question for a 05 CRF250 [Re: 3BallzEmpty]
pmkkdx Offline
ha, found a cross reference... http://www.sparkplugs.com/
can either go by part number OR by plowing thru down to specific bike...
NGK - IMR9C-9HES then click List applications for part number IMR9C-9HES
Motorcycles, Minibikes, Mopeds, Scooters HONDA 2005 CBR1000RR/R REPSOL EDITION 1000
Motorcycles, Minibikes, Mopeds, Scooters HONDA 2006-2005 CBR600RR 4 plugs needed 600
Motorcycles, Minibikes, Mopeds, Scooters HONDA 2007-2004 CBR1000RR 1000
Extreme Long Life Laser Iridium Plug, 10mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Special Firing End Construction, Iridium Tipped Fine Wire Center Electrode with Platinum Tipped Ground Electrode, .036" (0.9mm) Gap
NGK - R0409B-8 then click List applications for part number BR9EG-N-8
Motorcycles, Minibikes, Mopeds, Scooters HONDA 2007-2005 CRF250R --- 250
Racing Plug, 10mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Stud Terminal, Half-Thread Shell, Ultra Fine Wire Platinum Tipped Center Electrode, Fine Wire Nickel Ground Electrode. NOTE: Does not include terminal nut, if necessary, order part #067606-0051
edit: oops, originally had the CR250 not the CRF ... my bad.
Edited by pmkkdx (05/02/08 06:07 PM)
~':/ Marcus \:'~
#351586 - 05/02/08 06:08 PM Re: Spark Plug Question for a 05 CRF250 [Re: pmkkdx]
3BallzEmpty Offline
I guess I'm taking this thing back and telling them to update their computer.
Thanks, pmkkdx!
#351587 - 05/02/08 06:11 PM Re: Spark Plug Question for a 05 CRF250 [Re: 3BallzEmpty]
pmkkdx Offline
might be worth a call to the TJs or CTPS to see??? that's what I would do anyway...
~':/ Marcus \:'~
#351588 - 05/02/08 06:31 PM Re: Spark Plug Question for a 05 CRF250 [Re: pmkkdx]
3BallzEmpty Offline
TJ's wasn't sure but what is CTPS?
#351589 - 05/02/08 06:55 PM Re: Spark Plug Question for a 05 CRF250 [Re: 3BallzEmpty]
Pull the plug out of the bike and see for yourself what is in there.
I thought I'd get a spair plug for my sons new RMZ 250 so I stoped at "A" suzuki shop to pick one up. I was told they didn't have it and it was going to be $63.000000 You got to be out of your mind if you think.......
#351590 - 05/03/08 09:25 AM Re: Spark Plug Question for a 05 CRF250 [Re: 3BallzEmpty]
pmkkdx Offline
Central Texas Power Sports ... in Georgetown ... yamaha, kawasaki, suzuki dealer ...
there is also Georgetown Honda too (but like most other Honda dealers, I think they cater alot more to the pavement crowd?)...
~':/ Marcus \:'~
