0 registered (), 981 Guests and 41 Spiders online.
#198250 - 10/21/05 11:54 PM uni air fileter XR50
glchromeice Offline
I have spent a long time looking around for an answer to this but no luck.
I just took out my air box and replaced with a uni filter. It looks pretty sweet and i'm stooked to try it.
Just wondering though, there was a tub that plugged into the side of the air box (which it then runs into a small box and then into the ignition case area. now that i have a foam air filter on i don't have anywhere to plug this tube and i dont know what it does. Is it the "crankcase vent" and i i should buy an external filter for it like this http://xr50.com/ap8mmcrvefi.html ? If so, is it possible to run without a filter or will dirt be sucked in or gas and junk leak out or what?
Im amazingly confused here and want to start this bike up. Thanks for your help!
#198251 - 10/22/05 11:43 AM Re: uni air fileter XR50 [Re: glchromeice]
ardfarkl Offline
Loc: Usually on here.
You hit it on the nose. It is the crank case vent. You can go down to Auto Zone and get a small filter that will plug into that hose. I know some people that never put anything on it, but I think that is dangerous.
Mike
#689
My mom hung me on a hook once...ONCE!!
