0 registered (), 1692 Guests and 64 Spiders online.
#130711 - 10/29/04 08:26 AM kips valve?????
iridered2003 Offline
Loc: galveston tx
can anyone tell me what a kips valve is and how it works on a kdx 200?? can you tell me how to adjust it? thanks for any help!!!
2-2003 honda cr125! JM RACING motor and suspension/v force delta 2 reed's/fmf fatty gold/fmf turbine core 2/applied triple clamp's and renthal twin wall bar's! and a few other thing's i can't talk about!
#130712 - 10/29/04 09:14 AM Re: kips valve????? [Re: iridered2003]
pmkkdx Offline
pretty much everything you ever wanted to know about KIPS valve on a KDX.
http://www.justkdx.dirtrider.net/kips.html
~':/ Marcus \:'~
Laughter is the best medicine!!!
(I only have to amuse myself)
#130713 - 10/29/04 01:31 PM Re: kips valve????? [Re: pmkkdx]
Just a power valve.....isn't it????
#130714 - 11/01/04 08:37 AM Re: kips valve????? [Re: Fender_Bender]
pmkkdx Offline
LOL ... yep, just a fancy name for it (as far as I know )
~':/ Marcus \:'~
#130715 - 11/03/04 08:25 PM Re: kips valve????? [Re: iridered2003]
ChuckyBoy Offline
Loc: Woodway (Waco), Texas
From the manual...KIPS is an acronym for Kawasaki Integrated Powervalve System. It (they) it can't be adjusted. Depending on your premix and/or jetting, it does need to be de-carbonized from time to time though.
In addition to the site PMKDX listed, try Canadian Dave's KDX forum at www.dirtrider.net. A manual is a good start too.
I did my first topend last summer and I'm AMAZED at the engineering that has gone into the modern two strokes...especially the power valves!
Later,
Chuck
#130716 - 11/04/04 10:11 AM Re: kips valve????? [Re: ChuckyBoy]
Vintage_Vinnie Offline
Actually, the KIPS System CAN be adjusted. Moose Racing makes a "power valve tuning kit" for the Kawasaki KDX- it consists of a set of two (2) springs:
One is lighter than stock to allow the power valve to open faster (my favorite)
One is heavier than stock to allow the power valve to open slower (gives more predictable power for tight trails, mud, etc.)
The spring is what controls the centrifugal "governor" which opens and closes the valves. I think I paid about $42.00 for a set for my '91 KDX in 1992. For the money spent, it is quite the power enhancer and is easy to install.
Also, on another note- the KIPS valve is mechanical and is prone to gumming up, especially if you run a rich premix (smoky). It's a good idea to clean it thoroughly every ten rides or so.
Vintage Vinnie Make it on a Maico
#130717 - 11/04/04 04:24 PM Re: kips valve????? [Re: Vintage_Vinnie]
Loc: galveston tx
is it a big deal too take it out and clean it? i'm not stupid,i'm just a honda fan and these kawasaki's are new to me! thanks for all the info!!
#130718 - 11/04/04 05:55 PM Re: kips valve????? [Re: Vintage_Vinnie]
ChuckyBoy Offline
Ahh...I see. Those springs must be at the lower end of the actuating rod. When I rebuilt my top end I left the rod in place therefore I didn't see the springs. You learn something new everyday!
Chuck
#130719 - 11/04/04 06:23 PM Re: kips valve????? [Re: ChuckyBoy]
Tominator Offline
Poet At Large
We had a 90 KDX 200 a few years back. I inadvertently used weedeater gas in it, and it made about 10 miles before bogging down and choking to a halt. We pulled the KIPS cover off, and it was coated with old carbon and new syrupy crap from the bad premix. I got out the trusty Berryman's B-12, and sprayed it religiously. The crap washed away, the valve started moving again, we filled up with good gas and rode away. I redid the whole cleaning process again, and it ran great from then on.
"I'm neither Conservative nor Liberal, I'm Considerable!"
Tom Bailey
Team BFD
KTM 5-sumthin
#130720 - 11/04/04 07:49 PM Re: kips valve????? [Re: iridered2003]
Probably the best investment I ever made on that KDX was buying the service manual from Kawasaki. That thing was very well detailed and told you exactly how to do everything! The manual cost me $37.00 in 1991, and it was worth every dime!
Changing the power valve spring is easy- pop the clutch cover off, push, twist and dissemble the power valve gears and couplings (not much there really), then release the spring, replace it with a different one, then stick it all back together. It takes about forty five minutes.
The "upper part" of the KIPS (the gears and valves in the cylinder)- Unless you are mechanically inclined and can figure out a 3D puzzle of "this gear goes here this way, because it has to turn the half-gear that turns that other gear, so that all of the valves open and close together in perfect unison at the right time"- then BUY THE SERVICE MANUAL, it will save your ass.
Moderator:  Bill, Gumby
