0 registered (), 1398 Guests and 88 Spiders online.
#295280 - 05/15/07 10:22 PM stuck in reverse!!!!!
tyotertacomer Offline
I have an 01 yamaha beartracker. I went to back it out yeterday, put it in reverse and backed up. But I can't put it back in forward! I tried rocking it and it won't budge. Please help
thanks
#295281 - 05/16/07 05:03 PM Re: stuck in reverse!!!!! [Re: tyotertacomer]
Does it have linkage to the reverse shaft into the tranny or transfer case? If so I would lube and check all that as it is most likely the problem.
If you have no linkage and just use the gear shifter....... probably something inside the tranny.
#295282 - 06/05/07 03:05 PM Re: stuck in reverse!!!!! [Re: tyotertacomer]
sadirtydog Offline
Loc: San Antonio. Texas
I have an 01 YAMAHA BIG BEAR that does the same thing. I usually rock it and say a couple of choice words and eventually after much frustration it will shift. Let me know if you figure out what's wrong. Good Luck!
Danny
