68
24
23185 Members
38023 Topics
#82113 - 01/18/04 10:17 PM
Re: 1987 xr600r question??
[Re: scottmotox]
I think www.kbb.com or www.edmunds.com have prices for used bikes. My experience is that these bikes hit a floor and hold their value around $800 to $1000 unless there is something obviously wrong with them.
Hoop 2006 XR650R, the dual sport bike 2004 DL1000, the street bike
#82114 - 01/19/04 10:20 AM
[Re: Hoop]
Loc: Leander,TX
#82115 - 01/19/04 12:05 PM
[Re: scottmotox]
Poet At Large
I've owned several XR's, including a handful of 500 and 600's. Any decent 600 should be worth a grand or so. It will still be worth that in 5 years, too.
Check the valves, to keep it running right and starting good. Run the carb 1-2 jets richer than stock, and change the oil at a regular (8-10 hour) interval, and you'll be fine.
"I'm neither Conservative nor Liberal, I'm Considerable!"
Tom Bailey Team BFD KTM 5-sumthin
#82117 - 01/19/04 01:35 PM
[Re: scottmotox]
Those big XR's are virtually indestructible!!! Likewise I have owned several of the 500’s and 600’s. Tom is spot on!!, keep clean oil in them and the valves adjusted and they will run forever (as long as you don’t let them set up a few months and varnish the carb(s) ). In ’83 they put 2 carbs (or a 2 stage carb ) that was kinda tricky to adjust if they ever got out of sync but I am not sure how many years they had that configuration. About the only negative thing I can say about them, they were very heavy but the power is a rush! Good luck to your friend!
------°¿°-------- ~':/ Marcus \:'~ Laughter is the best medicine!!! (I only have to amuse myself)
#82118 - 01/19/04 04:49 PM
[Re: Tominator]
Loc: Very NW Austin, TX
Oil change every 8-10hrs? man I hope you recycle....
