#62589 - 08/25/03 11:14 PM '98 CR250 Fork Oil Level
Anonymous
Unregistered
what's the stock measurement for fork oil on a '98 CR250? (ie 100mm, 140mm, etc.)
Thanks ahead of time for your help
#62590 - 08/26/03 12:27 PM Re: '98 CR250 Fork Oil Level
vetboys Offline
Loc: You have No evidence!
Standard capacity is 373cc (12.6 oz.). If you're just changing fluid, spend alot of time pumping the old oil out and drain them for at least 30 minutes if possible. The damper still carries oil and the spring needs to drain off well.
Maximum capacity is 422cc, minimum capacity is 326cc.
Ronnie Jones
50B TSCEC #408
2009 CRF250X, with all the good stuff on it
#62591 - 11/22/03 06:59 PM Re: '98 CR250 Fork Oil Level [Re: vetboys]
2lo Offline
Loc: west texas
Does anyone know a site that has all the suspension setups and service instructions?
specs for fluids and things of that nature.
Cycle Parts Warehouse - www.cyclepartswarehouse.com
