SOLD
2012 Husaberg/KTM TE 300 - $4,250
Rental 999 Bars
KTM PHDS bar mounts
Enduro Engineering/Moose hand guards
ARC Levers
Motion Pro extended throttle cable
Slavens Mule High Compression Cylinder Head by S3 (8 hours on the rebuild)
Rekluse Core EXP Clutch
Rekluse Clutch Case
Rekluse external adjuster
ProTaper adjustable footpegs with stainless steel cleats
FMF Fatty pipe
FMF Turbine Core 2 silencer
Flatland Racing pipe guard
Enduro engineering seat
Extended brake reservoir front and rear
Husaberg factory rear brake guard
Tubliss 2.0 front and rear
Suspension re-sprung for 210 - 220lb rider (OEM springs included)
Front and rear suspension re-valved for woods/technical rocky trails
8 hours on new chain
8 hours Dirt Tricks sprockets front and rear (stock gearing)
TM Designworks factory chain guide
Mapping switch installed to switch from more aggressive to less aggressive power delivery
Most people, if you can find a 2012+ 300 are asking over $5,000. I'm not. I want it gone. My situation in life has changed up a bit in the last few years and riding has fallen by the wayside. Which also means if you don't lowball me you get a shit-ton of extra parts. Off the top of my head this includes two new air filters and 3 or more used ones, a bunch or oil, filter oil, chain cleaner, and chain lube. I have an extra set of Tubliss 2.0 for you and a barely used BIB Mousse for the rear tire. I have a set os Samco silicone hoses and a GPR under the bars steering stabilizer somewhere for you too. 2 Gas cans. A spare front fender and so on. Oh yeah and a brand new in the plastic Dunlop AT 81.
Haggle with me over the price and all of that goes away. I would rather give it to buddies for free than have someone lowball me.
Edited by petetothemax (05/28/18 05:51 PM)
Pete P.
TORCS #321
