#594780 - 03/20/18 11:55 AM 2009 KTM 250-300 XC-W
JVINCENT Offline
Veteran rider, second owner. Well maintained. 175 +/- total hours/115 hours on current top-end.
Originally a 250, added Slavens Racing 300 SXS Kit at 60 hours. Have the 250 cylinder, 250 XCW head and a 250 SX head and 250 ECM. Add a new piston and you've got yourself a 250.
Rekluse Z-Start Pro Clutch, with Rekluse basket, recently serviced
FMF Gnarly Pipe
FMF Q-Stealth Spark Arrestor
E-Line Carbon Skid Plate
OEM Lighting Kit (XC-W in '09 did not have lights installed)
Nuetech Tubliss insert on rear/HD Tube in front
Trail Tech Endurance II Speedo/Odo
Spare used plastic, including number plate
Spare progressive springs front/rear for #220 rider/OEM springs mounted at present
Motion Pro Speed Bleeders
SKF Mud Scapers for forks
Clear spare OEM tank
STR Brake Reservoir Master Cylinder Cooler
STR Brake Caliper Cooler
Hammerhead Designs +10 Shifter
Hammerhead Designs Brake Lever Tip
7602 Radiator Guards
Acerbis Handguards
New KTM Domino Grips
KTM Powerparts Tall Seat and stock seat
KTM Owners Manual, tool kit and briefcase
Spare SKF fork rebuild kit and swingarm bearing replacement kit
Numerous spare TwinAir filters
400W OEM Starter and 2015 starter bendix.
New battery
Texas Title in-hand
$3500. Can deliver within a reasonable driving distance from Houston with cash in-hand.
713-851-4149. No negotiations by phone or text, please.
300 right.pdf (76 downloads)
White tank left side.pdf (31 downloads)
300 Black tank.pdf (24 downloads)
ODO.pdf (19 downloads)
Edited by JVINCENT (03/23/18 11:16 AM)
Edit Reason: Added upgraded starter and battery.
#594976 - 04/06/18 09:13 AM Re: 2009 KTM 250-300 XC-W [Re: JVINCENT]
JVINCENT Offline
***SOLD***
Moderator:  BIZZZARE, Gumby, Lumberjack
