Page 2 of 2 < 1 2
#586718 - 02/13/16 04:51 AM Re: DYNO TUNING !!! [Re: KTMofNorthTexas]
Kid2watch Offline
That's a sweet set up...
#586728 - 02/13/16 07:00 PM Re: DYNO TUNING !!! [Re: Kid2watch]
jefe69 Offline
Loc: DFW
Wish yall could throw my pickup on there. It needs a tune after a lift, wheels, and tires. lol
#586785 - 02/17/16 12:31 AM Re: DYNO TUNING !!! [Re: jefe69]
KTMofNorthTexas Moderator Offline
Loc: Arlington Texas
Thank You, Its been alot of custom work getting it the way we wanted it.
Don't know how we got along with out it for so long, we use it alot.
Largest KTM parts stocking dealer in the Region.
#1 in KTM Motorcycle sales for the past three years.
SLMRacing.com
INFO@SLMRacing.com
817-275-2228
#586792 - 02/17/16 02:54 PM Re: DYNO TUNING !!! [Re: KTMofNorthTexas]
WANTED TO SHARE SOME OF THE LATEST RESULTS.
THIS ONE IS PRETTY IMPRESSIVE! THIS IS A STOCK 2016 250 SXF
IT MADE AWESOME HP STOCK BUT WAS A LITTLE ON THE RICH SIDE.
I WAS ABLE TO PULL ALMOST 2 HP OUT OF IT FROM JUST GETTING THE MAP PERFECT.
OVER 40 HP AT THE WHEEL FROM A 250 4 STROKE!! ITS A SCREAMER.
ILL POST A OLDER 250 NEXT
SLMRacing.com
INFO@SLMRacing.com
817-275-2228
#586793 - 02/17/16 02:56 PM Re: DYNO TUNING !!! [Re: KTMofNorthTexas]
THIS IS A 2014 250SXF
WITH FMF SLIP ON
BEFORE AND AFTER TUNING.
SLMRacing.com
INFO@SLMRacing.com
817-275-2228
#586794 - 02/17/16 02:59 PM Re: DYNO TUNING !!! [Re: KTMofNorthTexas]
THIS 2014 350 SXF SUPPRISED ME WITH SOME GREAT NUMBERS.
I LOVE THE NUMBERS THAT THE YOSHIMURA FULL PIPE PRODUCES!
2014 350 SXF ON PUMP GAS WITH FULL YOSH PIPE AND 71.2 HOURS ON ORIGINAL TOP END!
BOTH RUNS SAME SETUP, RESULTS ARE BEFORE AND AFTER TUNING.
OVER 50 HP AT THE WHEEL! THATS 450 TERRITORY! =)
Edited by KTMofNorthTexas (02/17/16 03:01 PM)
SLMRacing.com
INFO@SLMRacing.com
817-275-2228
#586795 - 02/17/16 03:04 PM Re: DYNO TUNING !!! [Re: KTMofNorthTexas]
THIS IS A 2016 450 XCF WITH FULL FMF PIPE ON VP'S U4.4 OXYGENATED FUEL,
BEFORE AND AFTER TUNE WITH SAME SETUP.
ITS A MONSTER LOTS OF TORQUE
Edited by KTMofNorthTexas (02/17/16 03:06 PM)
SLMRacing.com
INFO@SLMRacing.com
817-275-2228
#586841 - 02/18/16 09:25 PM Re: DYNO TUNING !!! [Re: KTMofNorthTexas]
2016 350 SXF WITH FULL FMF TI PIPE AND VPR FUEL
BROKE IT IN ON THE DYNO FOR A LITTLE OVER A HALF HOUR WITH 3 HEAT CYCLES.
THEN MADE SOME PASSES AND ADJUSTED THE FUELING.
WITH ONLY .9 HOURS ON THE ENGINE ITS MAKING SOME GREAT NUMBERS. IT WILL MAKE MORE AFTER A FEW MORE HOURS OF BREAK IN BUT WANTED TO PUBLISH THE RESULTS FOR YALL.
(THE LITTLE BUMPY PATCH IN THE HI RPM'S IS DUE TO THE BRAND NEW CHAIN LOOSENING UP AND SLAPPING A LITTLE, IT WOULD GO AWAY IF I TIGHTENED IT BUT FOR TUNING PURPOSES IT DIDN'T MATTER)
SLMRacing.com
INFO@SLMRacing.com
817-275-2228
#587155 - 03/03/16 02:13 PM DYNO TUNING !!! 1290 SUPER DUKE VS R1M [Re: KTMofNorthTexas]
2015 1290 SUPER DUKE KTM CLAIMS 180 HP
WITH NO CAT AND SLIP ON
VS
2015 R1M (THE $23,000 YAMAHA) YAMAHA CLAIMS 200 HP
BOTH DYNO TUNED
BOTH SOUND AWESOME AND ARE FUN TO RIDE BUT
THE DUKES MONSTROUS TORQUE AND SHORT GEARS MAKE IT CRAZY EVERY TIME YOU THROW A LEG OVER IT.
AND WHILE THE R1M SOUNDS BETTER THAN MOST ANY INLINE 4 I HAVE HEARD WITH STOCK CAMS THE SUPER DUKE WITH THAT HUGE RACE TWIN GETS MY VOTE IN THE SOUND DEPARTMENT.
SLMRacing.com
INFO@SLMRacing.com
817-275-2228
#587638 - 03/25/16 09:13 PM DYNO TUNING 16 450 FACTORY EDITION [Re: KTMofNorthTexas]
STOCK OUT OF THE CRATE
WITH ABOUT 20 MINUTES OF BREAK IN ON THE DYNO IT MADE 54.19 HP
IT NEEDS SOME MORE BREAK IN TIME ON THE RINGS AND IT WILL MAKE EVEN MORE.
HAD TO ADD SOME FUEL BECAUSE IT WAS A LITTLE LEAN OUT OF THE BOX.
SLMRacing.com
INFO@SLMRacing.com
817-275-2228
Page 2 of 2 < 1 2
Moderator:  Advocare, KTMofNorthTexas
