Finally, some decent weather & sunshine on the weekend! Currently there is little in the way of marked trails at the 1100 but there are several open areas that should be fun to ride. Most of the levees have yet to be marked and linked up. Also a lot of mowing & bobcat work is left to be done. I'll bring a couple of Google Earth maps to help point you in the right directions. Extreme caution should exercised near the mined areas and tall weed and grass. There are bike swallowing washouts and hidden dangers yet to be marked or removed. Only the NE section(~25%) of the property is fenced for cattle...if you go through a closed gate, close it behind you. Basically use common sense until you know your way around and we get things marked.
Cheers
Kenny
2006 KTM 453 EXC
Team B.A.P. Racing
TRH/Skull Creek #611
AMA Member
"iz spellz dis way on porpose!" :-p
