#55861 - 06/23/03 11:06 PM Raptor ProPeg Nerf Bars
TXrappy Offline
Just got my AC Racing Propegs in for my Raptor, and started out for a quick bolt on until I hit the shift linkage. The tolerances are way too tight and my stock shifter won't go on! Has anyone else had luck with these? If so what did you have to do to get around it???
'03 Raptor #78 Scorpion Exhaust AC Propeg Nerfs Elka Quad Rate on Denton Longravel front end Elka Dual Rate Rear RPM Dominator Axle Prodesign ProFlow Foam GYT-R Jetkit w/ 150/155 DID X-Ring on Ironman 13/41 Sprokets
#55862 - 02/23/04 08:31 AM Re: Raptor ProPeg Nerf Bars [Re: TXrappy]
thumper355 Offline
Loc: Fort Worth
I just bought the AC nerf bars with the pegs and rear heal guards. I had the same problem. I did a slight grinding job on the stem. It worked really well. Let me know if this helped.
#55863 - 03/25/07 09:18 AM Re: Raptor ProPeg Nerf Bars [Re: thumper355]
Talljess Offline
That was the reason I bought GYTR Nerfs for my rappy..just had them powdercoated
