#530495 - 03/17/12 10:34 PM Where(or who) to get fabrication done?
swoodard23 Offline
Hello all,
I just bought a 1962 Land rover 109 with a ford 289 conversion. I am wanting to swap out the weak stock axles and transmission for american parts. Who should I contact in Abilene for this kind of work? I would like to do it myself but do not trust my welding skills with my dinky 110 flux core welder and do not think I could wrangle the heavy suspension parts by myself. So basically I need someone who can install a ford transmission, weld transmission supports and align and weld spring perches for the axles, and insure the steering still works? The floor of the cab comes up so the transmission can be removed from the top. I usually do all the work on my cars myself but this project is a little too BIG. Any suggestions?
Thanks,
Scott
#531641 - 03/27/12 06:07 AM Re: Where(or who) to get fabrication done? [Re: swoodard23]
TonyR Moderator Offline
Loc: Abilene, Texas
Scott,
Sorry for the delay, busy time and not many are monitoring the board. What axles were you thinking of installing?
Tony
Tony Roper - Veep and Web "Guru?"
Big Country Off-Road
http://www.bigcountryoff-road.com
http://www.itsnotabuick.com
1986 CJ7/4.3/700R4/4:1 D300/AMC20 EZ-Locked/D44 Detroit/5.13/36" Wranglers/9.0RC
1974 Bronco buggy - in pieces
#531782 - 03/28/12 12:22 AM Re: Where(or who) to get fabrication done? [Re: TonyR]
swoodard23 Offline
I would like to put ford explorer axles in it with an AOD or C4 transmission and transfer case.
Thanks,
Scott
Moderator:  RajinCajun, TonyR
Cycle Parts Warehouse - www.cyclepartswarehouse.com
