yqygegam, akapepow, Ezel, evuhoje, asarjip
23099 Registered Users
1 registered (yqygegam), 463 Guests and 20 Spiders online.
23098 Members
38160 Topics
Max Online: 573 @ 05/04/20 10:29 AM
2005 Yamaha YZ 167
by pig
Yesterday at 12:47 PM
2016 KTM 65 SX $2750
by 525Brian
09/18/20 08:39 AM
1984 XR500R Semi OEM Restore Dual Sport $3,500 OBO
by Stuwbaby
09/12/20 12:27 PM
2018 KTM 250XC
by Cirus
09/07/20 12:58 PM
#460593 - 03/29/10 08:34 PM KX100 Shifting Problem
kozzer1 Offline
Loc: Gun Barrel City, Texas
I took my son's friend riding with us this weekend. About 2 laps into his ride his shift lever quit doing anything. The clutch still works but when you pull up or push down on the lever it moves but doesn't shift the gears. Not sure as I'm not real familiar with this bike, bent shift fork? Is there a spring inside? Thanks for any ideas.
2007 RM125
2004 YZ250
#498048 - 03/12/11 07:59 PM Re: KX100 Shifting Problem [Re: kozzer1]
Beech Offline
Loc: Austin
We had a '99 KX100 that did the same thing. The shift shaft broke and would not turn the shift drum. So you could not change gears. New shift shaft assembly fixed it. We had a repair manual and followed the steps to make the repair. The only hard part of the repair was removing the clutch hub - requires a tool to hold the hub.
#501518 - 04/15/11 12:05 PM Re: KX100 Shifting Problem [Re: Beech]
WRP Offline
It sounds like the shifter mechanism, or even a bent shift fork. A slight over-rev can cause this pretty easily.
Luke
Luke
www.woodsriderparts.com
2002 KTM 300 EXC
2009 Husky WR250
