2010 Texas Events || TON Forums | Classifieds | Gallery | Links | Weather | Home   || OEM parts & online schematics || Cycle Gear
#452307 - 02/02/10 10:42 PM 350 tbi conversion
88yota Offline
Loc: lubbock
im having a problem and it boggles my mind.... i have a 84 350 converted to tbi. when trying to time it "unpluged"..... it seems to run great if the timing mark is strait up and down w the water pump and all the way down atleast 45 degrees to the passenger side. when you try and bring it to the timing mark it runs like crap and most of the time wont run at all there. any ideas.... are the harmonic ballencers the same from carb to tbi?
Edited by 88yota (02/02/10 10:47 PM)
88 YOTA 4-RUNNER FULLWIDTH (14bolt with a Lincon Locker , DANA 44 with cromos and ausie locker....4:10's that is) TBI 350, TURBO 350 TRANNY NP 203/205 DOUBLER , SITTIN ON 35'S!!!!!!! GET R DONE OVER... KRSH!!!!!
#452354 - 02/03/10 10:13 AM Re: 350 tbi conversion [Re: 88yota]
tricksjeep Moderator Offline
Loc: Lubbock
Make sure the timing gear in right.
good luck
Patrick (Trick)
#452366 - 02/03/10 11:54 AM Re: 350 tbi conversion [Re: tricksjeep]
FullSizeJeeper Offline
Loc: Lubbock
Sounds like you need to move each plug wire on the distributor one spot clockwise and time it again. If your mark is off 45 degrees, then your beginning setup is on another piston. When timing it, have the key off, unplug the advance wire, start the motor, adjust timing to 0 degrees, kill the engine (key off), plug wire back in, and you're done.
Edited by FullSizeJeeper (02/03/10 11:59 AM)
'85 Jeep Grand Wagoneer Aaron
#452555 - 02/04/10 12:27 PM Re: 350 tbi conversion [Re: tricksjeep]
88yota Offline
Loc: lubbock
it runs like glass when its on that side? so im thinkin its prolly not timed incorrectly internally. im wondering if maybe the ballencer may have spun on its self bc its not new by anymeans.... i will try moving all the wires one over and see what i come up with and get back to yall thanks you guys
#452760 - 02/05/10 02:19 PM Re: 350 tbi conversion [Re: 88yota]
Loc: Lubbock
Try the wires first. If that doesn't work, pull the balancer off and see if the key on the shaft didn't sheer off.
#452825 - 02/05/10 08:36 PM Re: 350 tbi conversion [Re: FullSizeJeeper]
88yota Offline
Loc: lubbock
will do thanks guys
#454827 - 02/17/10 10:29 PM Re: 350 tbi conversion [Re: 88yota]
Loc: Lubbock
did it work?
Patrick (Trick)
Moderator:  Tracker, tricksjeep
TJ's Cycle - 6208 North Lamar - Austin, TX 78752 - 512-453-6255
Central Texas PowerSports - 2534 N. Austin Ave. - Georgetown, TX 78626 - 512-948-9922
Cycle Nation Powersports - 13806 N.Hwy 183 - Austin, Tx 78750 - 512.331.6686
Avant Motorcycles - 2439 US 90 West - Castroville, Texas 78009 - 210-892-2990
Hidden Falls Adventure Park - 7420 E. FM 1431 - Marble Falls, Tx 78654 - 830.798.9820
TON Champion Energy Offer
TON ATT Referral Offer
TON TradeKing Offer
CycleGear.com Gaurantees
Shop Cycle Gear for Motorcycle Parts and Apparel
MotoSport, Inc.
Outside Hub
