2010 Texas Events || TON Forums | Classifieds | Gallery | Links | Weather | Home   || OEM parts & online schematics || Cycle Gear
#451670 - 01/29/10 06:44 PM broncobrando Solid Axle Swapage
broncobrando Offline
Loc: Abilene, Dyess AFB
Well guys I finally nailed down a guy that sold me his axle for 275. My wife is taking delivery tomorrow. SO the build begins!
1994 Ford Bronco Eddie Bauer 5.0
Ford 8.8 Eaton ELocker 4.56
Dana 44 TTB Open 4.56
BW1356
E4OD
35/12.50R15 BFG MUD 15x10 Eagle Alloy
Dana 44 solid axle swap and 14" travel suspension in progress...
#451708 - 01/30/10 04:10 AM Re: broncobrando Solid Axle Swapage [Re: broncobrando]
does anyone have a reamer for chevy HD tierods? ording a kit right now and need to know if I have to buy the 70 dollar reamer?
BW1356
E4OD
#451714 - 01/30/10 08:08 AM Re: broncobrando Solid Axle Swapage [Re: broncobrando]
95YJman Offline
Loc: Abilene, TX
There is a reamer at Mike's that I aquired back when I was doing mine. I'll check when I'm out there today.
95YJ 4.0, NP435/NP205 twin sticked, HP44/60, 5.38's, 36x12.50 Goodyear MTIIs on recentered H1's
#451719 - 01/30/10 09:12 AM Re: broncobrando Solid Axle Swapage [Re: 95YJman]
thank you so much, found a steering kit with this stuff
(1) 35" LENGTH OF 1 1/2" O.D. x 1/4" WALL D.O.M. TUBING
(1) 47" LENGTH OF 1 1/2" O.D. x 1/4" WALL D.O.M. TUBING
(2) 7/8-18 LEFT HAND WELD IN THREADED INSERTS
(2) 7/8-18 RIGHT HAND WELD IN THREADED INSERTS
(2) 7/8-18 LEFT HAND JAM NUTS
(2) 7/8-18 RIGHT HAND JAM NUTS
(1) ES2026R DRAG LINK END
(1) ES2027L DRAG LINK END
(1) ES2233L TIE ROD END
(1) ES2234R TIE ROD END
for 215 shipped!
BW1356
E4OD
#451992 - 02/01/10 09:03 AM Re: broncobrando Solid Axle Swapage [Re: broncobrando]
bought the said steering kit above and a few other things for my build.
Stock radius arms 35 bucks for the arms
45 bucks for coil perches and possible caps for above radius arsm
Plans are to cut them down weld up DOM back to heims for the extra long radius arms and custom crossmember.
Anyone have a place where i can buy a welder locally for a good price, I would like to go with the Hobart 187 amp unit and someone to watch my welds..
Tired of buying off the shelf, time to start welding my own rigs.
BW1356
E4OD
#452017 - 02/01/10 10:57 AM Re: broncobrando Solid Axle Swapage [Re: broncobrando]
95YJman Offline
Loc: Abilene, TX
To find a good deal on a welder, I'd keep up with craigslist and the thrifty nickle. Other than that, any of the welding supply places, and tractor supply will sell you one. Don't know about the good price though.
#452019 - 02/01/10 11:13 AM Re: broncobrando Solid Axle Swapage [Re: 95YJman]
RajinCajun Moderator Offline
Loc: Hawley TX
Make sure you have 220 power available. The Hobarts are good for the price. Order of quality to me would be Miller, Lincoln, Hobart. I put Miller a little higher because you can only buy them at a dealer/welding supply place, I think the Lincoln's sold at Home Depot etc are a little lower quality (but still good units, just hope quality doesn't falter). Hobarts are a good welder. I can give you some pointers and direction. I would also suggest taking the welding classes at Cisco, the AF pays for them smile
Michael Strickland
Web Master
www.BigCountryOff-Road.com
70 Ford Bronco, 39.5" Boggers, SD axles front and rear 302 EFI
#452209 - 02/02/10 11:45 AM Re: broncobrando Solid Axle Swapage [Re: RajinCajun]
Thanks guys,
I think I am going to buy a stick welder since I want to do thick stuff, may get a tombstone lincoln or a hobart stickmate 235/160 AC/DC
I was just looking at Cisco a couple days ago. wanna get a cert!
BW1356
E4OD
#452284 - 02/02/10 08:46 PM Re: broncobrando Solid Axle Swapage [Re: broncobrando]
Loc: Hawley TX
We need to talk face to face smile Stick welder is not what you want... don't feel like typing a novel smile
Michael Strickland
Web Master
#452344 - 02/03/10 08:28 AM Re: broncobrando Solid Axle Swapage [Re: RajinCajun]
robs88yj Offline
x2 on gettign a MIG.
x2 on 220v
take the classes and get comfortable with it. Mig is the only way to go for what we do. Can it be done with a stick welder? Yup. Fast? Nope. Forgiving? Nope.
'88YJ w/4.0l MPFI, 39.5" TSL's, Homegrown Bumpers/tire carrier, Spring over, 5.38 gears Frt & Rear, Dana 50 front and Dana 60 rear, stretched frame 6 inches
Moderator:  RajinCajun, TonyR
TJ's Cycle - 6208 North Lamar - Austin, TX 78752 - 512-453-6255
Central Texas PowerSports - 2534 N. Austin Ave. - Georgetown, TX 78626 - 512-948-9922
Cycle Nation Powersports - 13806 N.Hwy 183 - Austin, Tx 78750 - 512.331.6686
Avant Motorcycles - 2439 US 90 West - Castroville, Texas 78009 - 210-892-2990
Hidden Falls Adventure Park - 7420 E. FM 1431 - Marble Falls, Tx 78654 - 830.798.9820
TON Champion Energy Offer
TON ATT Referral Offer
TON TradeKing Offer
CycleGear.com Gaurantees
Shop Cycle Gear for Motorcycle Parts and Apparel
MotoSport, Inc.
Outside Hub
