#451083 - 01/26/10 08:22 AM
wtb dana 44 from 73-79 ford trucks
Loc: Abilene, Dyess AFB
email me or send me a pm. brfertig at yahoo dot com
1994 Ford Bronco Eddie Bauer 5.0 Ford 8.8 Eaton ELocker 4.56 Dana 44 TTB Open 4.56 BW1356 E4OD 35/12.50R15 BFG MUD 15x10 Eagle Alloy Dana 44 solid axle swap and 14" travel suspension in progress...
#451085 - 01/26/10 08:26 AM
Re: wtb dana 44 from 73-79 ford trucks
[Re: broncobrando]
i really want to get the sas done on my truck in the next 4 months before i deploy again, i am trying to save some time so if someone would be willing to look for me if they are at FM600 salavage yard or one of the two salvage yards just south of it, I would pay a finders fee (within reason) or just help a brother out. I cant call them out here or I would do it myself. Thanks again.
#451095 - 01/26/10 09:17 AM
[Re: broncobrando]
Loc: Abilene, TX
Be careful on the year models. I think 77 will be as far back as you want to go on a 3/4 ton D44. Before that, they were low pinion, with small u-joints, and just before that they had closed knuckles and drum brakes. Check out: http://77cj.littlekeylime.com/web_rs44.html for a plethora of info.
95YJ 4.0, NP435/NP205 twin sticked, HP44/60, 5.38's, 36x12.50 Goodyear MTIIs on recentered H1's
#451099 - 01/26/10 09:30 AM
[Re: 95YJman]
Loc: Hawley TX
Sam there is your opportunity to upgrade to a D60  I am just saying
Michael Strickland Web Master www.BigCountryOff-Road.com70 Ford Bronco, 39.5" Boggers, SD axles front and rear 302 EFI
#451109 - 01/26/10 10:41 AM
[Re: RajinCajun]
i have permanent screen burn in from the littlekeylime website, been there alot. the thing is i am already $$$ deep in the dana 44 parts and can do the swap on the cheap. i know bigger is better but 35's are where i plan to stay for now. as for the different years if its older than and including 77 then I am going to build it with better u joints and what not, the 78-79 has the thicker axle tubes and better parts including the F250 (some) 8 lug, flat top knuckes, HD spindles, brakes, etc... Just think that the d44 is going to do me well, could you all keep an eye out for me?
#451111 - 01/26/10 10:43 AM
[Re: broncobrando]
of course you know where i can find a d60!!!
#451114 - 01/26/10 11:06 AM
[Re: broncobrando]
Loc: Hawley TX
I meant Sam could sell you his D44 and upgrade his to a D60
#451123 - 01/26/10 11:37 AM
[Re: RajinCajun]
i see he is running the d44 on a yj, leaf sprung I assume? Makes for an easy swap, just weld in shackle mounts. Been looking to buy a hobart welder as well. I LIKE the idea!
#451208 - 01/26/10 07:29 PM
[Re: broncobrando]
Loc: Abilene, TX
I love the IDEA, I just can't blow my build funds to get an axle, replace parts, and regear. If I did that now, I would be back to square one on my doubler, and suspension work.
Damn it, now you got my brain working...
#451213 - 01/26/10 07:56 PM
[Re: 95YJman]
Loc: Abilene, TX
Just did a quick 'shopping trip' and it would be about $1200 in parts, NOT COUNTING the axle itself to upgrade. This is assuming my steering links would work, and that the axle has good brakes/rotors, and hubs. Best case, I'd be looking at $2000 ($800 axle...yeah right). Granted, my 44 is built, but that is still a big chunk of change.
270 Steering arms 360 Lockrite locker 165 Install kit 200 Gears 120 Kingpin kits
Texas Offroad Network Sponsors & Partners
Texas Offroad Network Affiliate Programs
