#209252 - 12/31/05 03:21 AM POP UP QUESTION
125mx Offline
Loc: Conroe Texas
Im buying a popup trailer it has a 110 ac unit in it its an older model trailer and what im wanting to know is what is the smalleset gen that i can get for this trailr also anthor qustion i have is refrig its got an old ice box in it now im thingking of puttin in a dorm size frig and just running it off 110v and hooking say a invertor to batteries fro towing and hooking up a wire to my truck to chrgethe batteries when i poull it down the road any ideas on how to do that and is is it a good idea or not when im camping then i can just plug it in and the frig will run thanks for any help n these issues you can give me
#209253 - 12/31/05 04:46 AM Re: POP UP QUESTION [Re: 125mx]
TomXR400 Offline
Loc: Fort Worth, TX
it depends on what you will be running... if you have an a/c you would want atleast a 3500w. Also those plug in ceramic heaters are usually 1500 watts. My 3500 watt generator will run the 1500 watt heater all night on 3.5 gallons of gas. The fridge doesn't seem to make that much difference. I got the generator at pep boys for $319, but now it is on sale for $279.
#209254 - 01/01/06 04:38 PM Re: POP UP QUESTION [Re: 125mx]
Sicko Offline
Loc: Princeton, Texas
Ohm's Law P=E X I {Watts = voltage X current}
If you have two of these factors you can find the sum.
118 volts is the norm. Locate the devices you want to operate with a generator and add up the amps they will pull. Some devices have a surge pull like motors on furnaces and AC units so that needs to be a factor as well.
I have a pop up as well and I did like Tom. I got one of those 3500w chinese units from Pep Boys and couldn't be happier. Very efficient and quite.
The inverter in the camper is rated at 15 amps and we run the furnace, lights, TV and fridge at the same time with hardly any load on the generator.
As far as the batteries, I have a 650 cca deep cycle battery and the truck charges it while on the way to our destination. Plus it keeps the fridge running while I tow. If you are just running the battery say at night and the heater runs it down the generator can be used to recharge it.
Marc Haught
250xc
#209255 - 01/01/06 04:55 PM Re: POP UP QUESTION [Re: Sicko]
125mx Offline
Loc: Conroe Texas
thanks for all the info
