If it is like the parking break system on the Warrior, you would follow the wire from the clutch lever to where it connects. Then disconnect it and toss away from quad. You should be left with a female connector on the quad. Now just cut yourself a little jumper wire and stick it in one side of the female connecter then plug the other end of your little jumper on the other side of the same female plug. Wrap it up tightly with some electical tape......by-passed!!!
